Colored Pot Knobs and Faders
Forums Forums Qu Forums Qu general discussions Colored Pot Knobs and Faders
This topic contains 38 replies, has 10 voices, and was last updated by Profile photo of Base Mell Base Mell 2 years, 3 months ago.
Viewing 15 posts - 16 through 30 (of 39 total)
  • #60641
    Profile photo of MarkPAman
    MarkPAman
    No. 🙁
    OK so I put a file into DropBox & then open DropBox in my browser. Highlight the file, click “Share”, click “Create Link”, click “Show Link”, copy it, then paste it here:
    https://www.dropbox.com/s/3gz2a3vwd3u9wny/Hello.jpg?dl=0
    Does that work?
    #60642
    MarkPAman
    OK working for me…..
    #60643
    Profile photo of GCumbee
    GCumbee
    I see a weird pic of an elephant on that link. Correct Mark?
    #60644
    MarkPAman
    Correct!
    #60645
    Profile photo of Andreas
    Andreas
    Moderator
    …now how to get this picture out of my mind: Qu equipped with Elephant Pot Knobs… 😉
    #60647
    MarkPAman
    Does this help?
    Darth Fader
    #60656
    Profile photo of joel77
    joel77
    QU fader knob 1
    Is this working for anyone else?
    Obviously I don’t post enough in internet forums!! lol
    #60657
    joel77
    QU fader knobs 2
    #60658
    joel77
    QU fader knobs 3
    #60659
    joel77
    I don’t know if these are showing yet. I see a box with the descriptor in it. When I click on it, it does open the correct picture. Not figuring out how to actually have the picture show in my posts.
    Anyway, if you can view them, the first and third pictures show the knobs from different angles. The black is standard QU fader knob. The white is a knob I robbed from an old A&H GL2 mixer. The red knob is one that I just purchased.
    The second picture is a shot of the under side. The slot that fits over the “T” of the fader is ever so slightly smaller on the red knob than the other two. It fits, but takes a bit to get it on and off. After I installed and removed this red knob a few times, it seemed to loosen up a bit.
    These are going to work fine for me. It’s not like I’m changing knobs during a show, so if it takes a few seconds longer, that’s OK.
    Hope this helps others in their quest for various colors of fader knobs for the QU mixers.
    #60660
    joel77
    4
    My current collection.
    #60661
    joel77
    Well, for some strange reason, I have to right click on the box and select “open image in new tab” to get it to show. hmmmm ……
    #60666
    Andreas
    Moderator
    I’ve just attached your pictures to your posts, didn’t had a problem with that. Embedding HTML tags obviously isn’t supported here.
    #60683
    joel77
    Thanks Andreas. Can you explain how you did that. I’m obviously missing something fairly simple.
    Thanks for doing that.
    Joel
    #60684
    Andreas
    Moderator
    Just used the attachment upload button as you did with your first post which failed due to size limitation.
