Color Chooser RGB
Forums Forums SQ Forums SQ feature suggestions Color Chooser RGB
This topic contains 42 replies, has 32 voices, and was last updated by Profile photo of Dilettant Dilettant 4 days, 22 hours ago.
Viewing 15 posts - 16 through 30 (of 43 total)
  • #83448
    Profile photo of torstendrums
    torstendrums
    +1
    #83513
    Profile photo of TonmeisterDaniel
    TonmeisterDaniel
    +1 for more colours. Right now there are not enough to visualise all different types of channels (different colours for ach kind of input signal such as drums/perc, vocals, guitars, bass and so on plus the other channels like fx send, return, aux, group, matrix, midi and so on)
    #84053
    Profile photo of New2SQ
    New2SQ
    More colors and inversion please!
    #85619
    Profile photo of woutersnoei
    woutersnoei
    +1 more color options
    #85915
    Profile photo of iandrewc
    iandrewc
    +1 on even a limited color picker, but if not a color picker, all primary/complementary colors would be amazing!
    #86152
    Profile photo of DJBeatz
    DJBeatz
    +1 for more colors.
    I also can’t use the dark blue and red because there’s not enough contrast on the title strips
    #86155
    Profile photo of Mfk0815
    Mfk0815
    Hmm, A&H opened that again by presenting the listen signal on the soft rotaries in a bright orange color;-) To they can’t argument that only basic colors are possible for that displays.
    But even if I also think that dark blue and red is not well readable (I personally use them only for the male or female main vocal) I do not want to have the whole range of possible colors via a color picker. maybe 12-16 colors would be nice, but not more because they would not be really helpful imho.
    #90992
    Profile photo of Yann
    Yann
    +1 for more colors. I had the idea that on the color picker screen, we could press and hold a color and it would bring up a color spectrum bar, or a Hue and Saturation control. Make a color and save it into the block we chose. We can then keep that there and recall it in the future.
    #91032
    Profile photo of SteffenR
    SteffenR
    again and again this will not happen since the hardware is limited in the control possibilities of the strip lights
    as @mfk0815 said 12 to 16 colors would be enough
    #91079
    Profile photo of OlivierM
    OlivierM
    +1
    #91713
    Profile photo of ianbuss
    ianbuss
    +1 for some additional color options.
    I have a small show w/ 20 inputs but 11 outputs: 3 wedges, 3 IEMs, 18 input channels 2 utility / speciality channels, LR / Sub, Broadcast. I would really love to have some additional colors and just a little smarter text / UI display. EX: If you know black text on a dark blue background won’t work. Don’t make that an option. Putting white text on those dark backgrounds would be a huge win.
    Not all of us have 20-20 eyesight anymore and some of us keep misplacing our glasses on the line arrays or the drum riser XD
    #92427
    New2SQ
    @ianbuss I definitely want more colors, but the color of the text cannot be changed due to the design of the SQ.
    #94215
    Profile photo of nwegab
    nwegab
    Hi .@mfk0815 and .@SteffenR,
    Could you give us some information about this feature request?
    16 color palette is possible? What are the limitations of the hardware?
    These are RGB LEDs? Does the hardware enable the fine-tuning of the colors?
    The current 8 (5 usable) colors are an uncomfortable limitation, especially compared to the competitors.
    More and better colors could help a lot.
    Best Regards, Gabor
    #94224
    SteffenR
    Keith described it somewhere, that only 4bits used for color coding, so 16 colors in max including white and black
    but some colors in between where not that different from others to clearly separate them (orange is to close to red)
    wich competitor has more than 8 colors? I don’t remember one…
    #94248
    nwegab
    Behringer has more colors by having inverse colors (black background and colored text).
    If I understand well the LCD hardware has this limitation.
    Do the four bits means this below?
    Red – on/off
    Blue – on/off
    Green – on/off
    White – on/off
    Do you plan to change the number of possible colors from 8 to 16?
    Everybody could decide which color is useful, which is not …
