Forums › Forums › Qu Forums › Qu troubleshooting › Clock sounds through USB
This topic contains 16 replies, has 4 voices, and was last updated by volounteer 3 years, 8 months ago.
2020/07/01 at 8:11 am #93025
I have a problem that whenever I attach the desk to the computer via USB I get a constant noice that sounds like a clock noise. Has anyone else experienced this and how did you fix it?
2020/07/01 at 8:31 am #93026what kind of computer?
sounds like a ground problem or a sample rate mismatch2020/07/01 at 10:19 am #93029I use a collection of mac’s and the problem is the same on all of them – there is a regular tick that comes through on everything, all channels including Stereo ins from cd for example and both appears in input meters and records audibly. It does this through the USB form the QU16 and I have tried my BOSE mini-mixer and it doesn’t do this so definitely generated form the QU
2020/07/01 at 11:22 am #93030While it is possible that this could be coming from the Qu, it may also be due to the connection, something else taking up bandwidth on the USB bus (the Qu will use a lot more bandwidth than the Bose), USB power settings or sample rate settings.
I’d recommend ensuring you are recording at 48kHz, trying different USB cables and ports and switching off any power saving options that might be enabled.
If you’re still having problems, please contact us using support.allen-heath.com with more details about your setup (e.g. the models of mac you have tried and the program/settings you are using to record).Cheers,
Keith.2020/07/01 at 11:34 am #93031what is the software used to record?
and wich settings did you use?sample rate, buffer size, buffers used, latency reported from the DAW
do you use an aggregated device?2020/07/06 at 1:58 pm #93168hi I am using an apple mac and I have the same issues across 3 different devices while using Logic and playing anything directly through the desk into the computer – I have to admit to not knowing the rest of the technical questions
I connect directly to the MAC via USB and have tried two different cables that both work on a different mixer
2020/07/06 at 2:21 pm #93169I have to admit to not knowing the rest of the technical questions
if your mixer and your DAW project won’t match in sample rate you will hear clicks…
so you have to find out at wich sample rate is your DAW recording2020/07/09 at 1:15 pm #93241How do I do that – I am using Logic and have tried to find the sample rate but failing?
HELP PLEASE
2020/07/09 at 3:12 pm #93243you should ask a Logic guy
or consult your manual of Logicare there any other audio devices involved?
2020/07/09 at 3:41 pm #93244Like @SteffenR indicated, your problem is mac/DAW related and you need to learn how to use those with usb.
Many things can cause problems so you need to know what you are doing to set things up properly.There are large descriptions of the things you have to do with windoze to make it work right.
I would expect there are some similar ones for macs and logic.
Try reading them.2020/07/12 at 8:32 am #93296Hi and thnks for the advice – I have tried everything including re-setting my sample rates to match, everything is now at 48Khz and this has just made the electrical noises into hisses and click both more frequently i guess due to the sample rate, and slightly louder too.
I think it may well be tha there is a genuine problem with the USB board so can anyone suggest how I get the desk mended
Cheers
Robin
2020/07/12 at 9:37 am #93298Hi @angryfish (Robin),
I’ve had a search through the support system, but couldn’t find anything recent from you.
As suggested, please contact us so we can run through some troubleshooting before you send off your desk to be checked.Thanks,
Keith.2020/07/12 at 10:34 am #93301Please see the post above that I put up this morning re having reset matching sample rates
2020/07/12 at 4:57 pm #93306You are too quick to blame the Qu when there are so many other things on the PC side that are the likely cause.
You may use different macs but you used the same software.
You say you matched sample rates, but what did you do about buffer sizes and other critical parameters that can cause problems.Have you fully scrubbed your mac to optimize it for audio use?
How do you know your security software is not interfering with the usb ?
What about social media aps that phone home all the time?There are so many other more likely causes that you ignore in your haste to blame the Qu for the problems.
2020/07/12 at 7:23 pm #93307Because The repair people said it was the USB board – But thanks for the unfounded and personal criticism based on absolutely nothing – Hope others can be as useful when you have an issue
