Thank you Mark & Keith for your help. That solved the problem. I could see on the SQ-6 the available function
for EQ and Compressor but the statement at the top “Mix Ext In Unassigned” resulted in me assuming (incorrectly)
that there was no more configuration available. I should have spent some time tapping on the SQ-6 screen to see
if anything happened! Younger people will tap all over a screen, when they are trying to figure out how to configure
a function. I simply need to do that more! I also noticed if I had been using the iPad app I would have
seen immediately the delay value for adjustment! Oh well. Looks like our new live stream setup is going to require
around .20ms to sync the lip movement.
Thank you again.
Eric
You must be
logged in to view attached files.
