A couple of questions
Forums Forums Qu Forums Qu general discussions A couple of questions
This topic contains 23 replies, has 7 voices, and was last updated by Profile photo of Andreas Andreas 9 years ago.
  • #47561
    Andreas
    Moderator
    Does it still work when plugged into a computer? Maybe it’s just dead, have several sticks around which just stopped working suddenly (totally unrelated to the Qu!).
    #47567
    Profile photo of Creator
    Creator
    Yes it will work fine on a computer and if I put it in the board it will read, and even record. It just stops after a few minutes
    #47580
    Profile photo of titoen
    titoen
    When you go to computer. do you cut and paste or leave the recordings on the stick?
    Got this from Knowledge site
    “Don’t fill the USB drive with lots of multitrack projects if possible, as the drive can become fragmented requiring longer seek times to write”
    #47582
    Creator
    1) we don’t record multitrack. We record stereo from the qu-drive on top of the mixer not from the back usb.
    2) we pull them off the drive to edit, they are not left on the drive. So the drive is empty each week before we start.
    #47585
    Andreas
    Moderator
    Hmm, did you try to reformat the stick on the Qu? Just guessing…
    #47588
    Creator
    I reformatted a few weeks ago after it first happened and was ok for a couple of weeks then started doing it again. I’m beginning to wonder if it might just be the drive. It seems to work when it wants then other times it doesn’t
    #47593
    Andreas
    Moderator
    I’d suggest to try a different stick. You’re hopefully aware that flash drives degrade over time and may take longer to store data now and then. Maybe too long for the Qu, which then simply give up.
    #47596
    Creator
    The thing is, it’s not that old we are only a 6 month old church so it shouldn’t be bad, but I know they can fail. so maybe that’s all it is
    #47597
    Andreas
    Moderator
    “old” for a flashdrive isn’t measured in terms of time but usage.
    Not sure about the intended performance of that rugged flashdrive but audio streaming requires some guaranteed data rate over time, even for stereo recordings. Trying another stick should make things clearer…
