Forums › Forums › iLive Forums › Archived iLive Discussions › suggestions
This topic contains 537 replies, has 136 voices, and was last updated by KB7981 10 years, 10 months ago.
AuthorPosts
2010/05/10 at 5:20 pm #25569
I’d like the ability on a t-112 surface to take the left and center fader groups and make them run channel numbers 1-20 instead of bank B on the first group start at 13. Makes it a little harder when you’re looking for things. Maybe going bank A on the left and center sliders as 1-20, then 21 through 40 to bank B.
2010/05/10 at 8:10 pm #25572quote:
Originally posted by wavemakersdjI’d like the ability on a t-112 surface to take the left and center fader groups and make them run channel numbers 1-20 instead of bank B on the first group start at 13. Makes it a little harder when you’re looking for things. Maybe going bank A on the left and center sliders as 1-20, then 21 through 40 to bank B.
You can put them anywhere you want on the surface just remap the channels to the sliders you want…maybe I have misunderstood what you were asking.
112T/IDR48
2010/05/10 at 8:28 pm #25573quote:
Hi, thats what i also have been asking for. To link 2 banks instead of all 3 together so you can haven the left an middle banks linked. that give you 20 input channels linked (12+ throughout the layers. Makes it easier to adjust AUX or effect sends. I put them on the right bank, select an aux mix and can dial in 20 channels at once without changing layers.3 layers give you 60 channels an the fourth layer can be used for the other not so needed stuff.
Lieven
T112/IDR48
Save a tree, eat a beaver2010/05/10 at 8:53 pm #25574The ability to gang inputs and outputs like a PM5D – ie hold select down on the first channel and then press select on subsequent channels, also i would like Ganging to automatically include all parameters except routing and when only 2 channels are ganged they are nearly always gonna be stereo so “opposed panning” could be automatic as an option (but only optional)
How about more plugins, development on the fx section seems to have stopped,
+1 for excluding certain sections from global fader link mode.
Internal FX input naming should auto name the outputs too. This is double workload and a pita every new show.
Auto archive facility so that you dont lose everything by mistake … ( I certainly didnt do a whole show with multiple scenes and then recall a different show to copy some library files to my USB key, to go back to my original show only to find that all my scenes had disappeared! …. nope i certainly did NOT make that mistake……. errr honest)
Which leads me onto a place on the touch screen where a global library can reside. Its a long job recalling shows just to get that certain EQ or Compression setting that you forgot to copy on your USB key.
GW
2010/05/10 at 9:04 pm #25575It would be hugely beneficial to have some kind of MIX library for use on a monitor console. We’re constantly having to rebuild people’s mixes. The only other option is to save a number of scenes and copy and paste mixes back and forth between scenes. This is quite unwieldy.
2010/05/11 at 5:21 am #25576quote:
Originally posted by grahamwhiteHow about more plugins, development on the fx section seems to have stopped,
Yes, thats one of my biggest wishes – I desperatly need an Distortion Effect.
Any chance to get new FX here?2010/05/11 at 8:08 am #25577quote:
Lieven
T112/IDR48
Save a tree, eat a beaveri requested once a “delay function” if one hits the layer button- just the layer changes – if the finger remains on the layer button-all the layers (on the left) follow to the same layer.
( to explain you stay on the middle bank button just the left bank folloows and of course if you are on the right bank all the others follow)
cheers
daveallen&heath iLive-144 /idr 64 / idr 48 (and soon a dante
2010/05/11 at 11:56 am #25579Hi Msmelser
quote:
It would be hugely beneficial to have some kind of MIX library for use on a monitor console. We’re constantly having to rebuild people’s mixes. The only other option is to save a number of scenes and copy and paste mixes back and forth between scenes. This is quite unwieldy.Since 1.3 firmware there is the abilty to store complete input channels and mix channel processing that you can recall independantly to each input or mix channel.
or are you requesting the ability to save all of the current send levels to a specific mix? (e.g. Aux 1 – input channels send levels)
Regards
Sam A&H2010/05/12 at 12:17 am #25580– I need a new softkey function:
“last scene +1”– seperate Input and Output-Patchbay
2010/05/13 at 7:02 am #25586quote:
Lieven
T112/IDR48
Save a tree, eat a beaverO yes. I also working t112 on monitors and the right bank is my aux bank and center and left is input channel bank. Linking the center and left bank only will be very very useful!!! )
Thx
Mario from poland
T112/IDR482010/05/16 at 2:28 pm #25594I would like, as the LS9 does, to have the ability to have audio files on it that would cue/play automatically when I call up a particular scene.
Jonathan Wade
Suburban Legend Audio2010/05/17 at 5:42 am #25597Would be great if delay time of the FX shown could be switched to BPM, not only in MS.
And to say it again – an Distortion Effect.2010/05/17 at 7:14 pm #25604i´m interested in option to invert phase seperatly at all the mix-busses!
greetings from hamburg
2010/05/18 at 12:48 pm #25613quote:
Originally posted by kentlowtI would like an ACE to Ethernet adapter with asio drivers to be able to connect to a PC’s Ethernet port from an ACE port to multitrack record with. Two way audio would be fabulous but, one way is fine.
Yes I know there is ethersound and madi and at some point dante but, the cost…
112T/IDR48
My vote as well. If A&H would provide a virtual soundcard for ACE, I wouldn’t mind paying for that, as long as it costs less then Dante for instance.
Wouter
My prayers have been heard, Dante is coming!2010/05/18 at 1:35 pm #25615In the editor, it would be very nice if the user interface were sizable, in order to adapt the UI for best usability using a touchscreen laptop or PC with touchscreen monitor.
Editor: The faders: it would be nice if they reacted on the whole width of the strip and not just the visible width of the fader, since they are pretty tiny.
Wouter
My prayers have been heard, Dante is coming! -
AuthorPosts
The forum ‘Archived iLive Discussions’ is closed to new topics and replies.
