Forums › Forums › Qu Forums › Qu general discussions › 1.8 released…
This topic contains 66 replies, has 23 voices, and was last updated by Gospelklaus 6 years, 7 months ago.
AuthorPosts
2015/10/25 at 8:07 pm #51651
We were starting to run out of time and had to start playing so I just set their mixes manually and did the show. I’ll spend some more time with it this weekend and see what I can find. Like what I am seeing so far but I do agree with some of the other posters that the Spectrogram needs to be added to the Qu-Pad display. This would be a huge help when mixing from stage.
2015/10/26 at 11:51 pm #51694Hi,
Is there a way on the QU-Pac to control the output balance? I know it was added to the QU APP, but I can’t find a way to control it from the QU-Pac control panel. I’m sure I’m missing something simple. Any help would be greatly appreciated.
2015/10/27 at 4:52 pm #51710Overall how is 1.8 for everybody? Any issues? I’ve got the QU-16 and no dSnake.
Thanks.2015/10/27 at 4:58 pm #51714Only Issue (if you call it that) I’ve had is the need to reselect Mixes on musicians Qu-You apps. I suspect that is more to do with the App upgrade than the Mixer.
There is one issue I know about, but it doesn’t affect you (It involves getting dSnake outputs from Groups set in Mix mode).
2015/10/27 at 5:55 pm #51717Ok, thanks for the reply.
2015/10/28 at 2:21 am #51729Is there atleast an eta of when the updated app for Android is coming out? Half our band uses iPhone and half uses Android for the Qu-You app. My iPhone automatically upgraded the app and I went ahead and updated the mixer firmware to get my app working again. I assumed all updates would be rolled out at the same time… We’re getting by, but it would be great to get everyone up and running again! Thanks, Ben.
2015/11/29 at 10:49 am #52351Hi all,
A brief introduction, because I´m new in this forum:
I´m supervise the QU-24 in our church since 18 month. With this experience I can confirm, that the Qu-24 is among other applications pretty good for apps in houses of worship. Commendations to the development team!Referring to the postings of Gilly above I agree, that the restriction to have access with Qu-Pad only with the Admin-password is a step backwards. I know, that in earlier firmware releases it was possible to have full access on all functions of the console, which may include some major problem. So I partly understand the decision for release 1.8, that only the admin password has permission for Qu-Pad access.
But now I´m forced into the unsatisfactory situation to give the admin password to all, who must have access to the remote control via Qu-Pad. In this way the advantage of the admin level to keep the control over important settings is lost.My recommendation for the next firmware release is as follows:
• A user of the Qu-Pad have to be authorized with a password (Standard or Admin, the Basic level don’t´ require a password, if so defined in the settings)
• Depending of the password level the access rights will be given to the iPad
• The password depending access rights of the Qu-Pad are the same like the password depending access rights of the QU-24Best Regards from Germany
Klaus
AuthorPosts
You must be logged in to reply to this topic.
