Waves plugins and Qu16
Forums Forums Qu Forums Qu general discussions Waves plugins and Qu16
This topic contains 23 replies, has 11 voices, and was last updated by Profile photo of ianhind ianhind 6 years, 10 months ago.
Viewing 15 posts - 1 through 15 (of 24 total)
  • #38895
    Profile photo of yurcek
    yurcek
    Does anyone know if it is possible to use A&H q16 and Waves plugins in live sound?
    Like Behringer and Presonus through usb and firewire.
    https://www.waves.com/live-sound/presonus#setups
    https://www.waves.com/live-sound/behringer#setups
    #38910
    Profile photo of Nicola A&H
    Nicola A&H
    Keymaster
    You can use Waves Multirack Native on a Mac or PC computer for send / return effects (for example Aux 1 -> USB plugin -> ST1 channel) such as reverbs and delays.
    Inserting plugins on a channel is not possible I’m afraid, as the channel source is EITHER analogue (local/dSNAKE) OR USB.
    Hope this helps.
    #38919
    yurcek
    I used multirack with PreSonus …
    may be a more accurate description of how to use multitrack with sends/returns?
    thanks nicola
    #39335
    yurcek
    after 14 days i resolve the matter … work perfectly for each channel…i can use all waves and other plugins for live perform and recording…also on master channel for final image…
    thx
    #39339
    Profile photo of andiabwaerts
    andiabwaerts
    hi, yurcek. can you explain a bit more? thanks
    #42217
    Profile photo of andrescarbonel
    andrescarbonel
    Anyone please? I need run the pluggins, or i have to sold My qu 16, because a lot of my clients its using pluggins… Another vst host? Really thanks the help!
    #42225
    Profile photo of FantomXS
    FantomXS
    It should be possible to route the signal over CH1 into your DAW and send it through the DAW-Channel with your plugin back to CH2 (USB). But of course you have a latency.
    #42233
    andrescarbonel
    thanks for the replay! i try this and work perfectly, BUT i need to run pluggins like INSERTS, channel 1 (insert for example a compressor) an return to channel 1. I dont believe that my QU 16 doesnt work, when crappy equipment like Behrin6er and Pre5onus do the job.
    I DONT WANNA SOLD MY QUE 16!!!
    @yurcek, can explain us how to make work the pluggins?
    Thanxs!
    #42235
    Profile photo of [XAP]Bob
    [XAP]Bob
    Then you’ll need an external ADC into the DAW, and output to the QU16.
    The QU architecture doesn’t have externally routable inserts for the channels.
    #42236
    andrescarbonel
    i dont believe this, i do not understand why allen and heat doesnt resolve this. Every console out there work with waves.
    Bob thanks for the response but i dont like convert my signals 2 times.
    @yurcek you are my last chance!
    #42237
    [XAP]Bob
    Don’t convert it twice – convert it into the DAW, then feed it via USB to the QU16.
    Note I don’t work for A&H, but looking at the specs it’s simply not supported…
    #42238
    andrescarbonel
    Bob thanks for the response again, i understand what you explain me, but we need and extra converter and dont using the converters of the desk. I dont carry extra things. Im afraid to tell that the qu 16 doesnt work for me. Im triying to still investigate, because we need so much to run the pluggins. But if dont work i really need to buy other desk from other brand.
    #42256
    FantomXS
    I can understand the wish. It would be nice to have this feature, but: Its not implemented.
    If you need this function, you have to make a decision: Qu-16 & Workaround oder another mixer. The Qu-16 is a great mixer and it works very good for my in my home studio and on stage. If i had the choice to buy a new digital mixer today, it probably would be the same decision for Allen & Heath. For me it is a question of trust in Alen&Heath and bad experience with other brands.
    Maybe, but i think the chance is low, A&H will make a solution for your problem.
    #42258
    [XAP]Bob
    The only other solution is to route out over USB and back in to different channels.
    I’m not sure whether this can be done simultaneously (i.e. take Channel 1 insert point out to the DAW and return it to channel 2 over the same USB connection?!?
    If it can then you’re halving your channel count, so you just need a bigger QU 😉 😀
    #42259
    [XAP]Bob
    Also – https://www.waves.com/live-sound/allen-heath#native
    That’s not a QU in the picture…
