Qu Android app, anyone interested?
Forums Forums Qu Forums Qu general discussions Qu Android app, anyone interested?
This topic contains 152 replies, has 42 voices, and was last updated by Profile photo of Frank Frank 2 weeks, 2 days ago.
Viewing 15 posts - 31 through 45 (of 153 total)
  • #52399
    Profile photo of Tommy
    Tommy
    Yeah, I went straight to Google Play from my phone and couldn’t find it. When I went from the link after applying, it came up without a problem. Thanks! I look forward to playing with it to see how well it works.
    #52410
    Profile photo of andrescarbonel
    andrescarbonel
    You can install the app on android emulator for Windows to use on a pc ?
    eq over the RTA can be very useful in a larger screen.
    #52411
    Profile photo of davidgiga1993
    davidgiga1993
    Yes that’s possible.
    The free version will be available for direct download soon so it can be installed on devices / emulators without play store access.
    #52426
    Profile photo of robbocurry
    robbocurry
    Excuse my ignorance, I’m new to the non Apple tablet world!
    I’ve just bought an Amazon Fire HD in a “Black Friday” sale but not having any success installing your app! I take it that it will be coming to the Amazon store too at some stage? Wasn’t able to get either version from the Google play links, even after signing up for the beta.
    Have the Behringer version installed just to see what it was like;)
    Quite a turnaround for me but I like the idea of controlling the desk on something that only cost £34.99!!!
    You advice would be greatly appreciated:)
    #52430
    davidgiga1993
    No problem 🙂
    Yes the beta is currently for devices with Google Play access only as amazon still has no proper beta testing mechanism. But the release version will br available on Amazom as well.
    #52454
    Profile photo of fgrillet
    fgrillet
    Good Evening davidgiga1993 (10h45 PM in France…)
    I haven’t yet acquired a Qu (certainly a Qu-Pac) but the fact of knowing that an application for Android make me happy 😉
    I have an ASUS 11.2-inch tablet that can especially connect aRJ-45 plug and I always have a nearby cable if WiFi does not work properly. As soon as I have my console, I subscribe to be a beta tester 😉
    Thanks a lot for you initiative and best regards,
    François
    #52756
    Profile photo of Eddy_current
    Eddy_current
    Hi, it looks as though the excellent Android Mixing station QU and Mixing Station QU Pro are now available from the Google play store. I have been running it for a couple of weeks on a Amazon fire (side loaded) that I like robocurry picked up in the Black Friday deals, even on this it seems more responsive than the ipad app. Thanks davidgiga1993.
    #52764
    robbocurry
    @davidgiga1993
    Great job in developing the app!
    I’ve just loaded the free version (don’t worry, paid one plus donation coming up when I update my card details with Amazon!)
    Just wondering if the input/output metering are features of the paid app as they aren’t showing in the free version on the channel strips, mix outputs, LR etc.
    Everything else seems to work, buttons, faders et al but no “feedback” from the inputs to the Amazon Fire I’m using.
    Any help would be greatly appreciated and thanks again for your hard work!
    #52766
    robbocurry
    Sorted!
    Bought the pro version and ticked “allow bus processing access” and all is working as expected. Sweet app, brilliant to have this alternative to my iPads!!
    #52775
    davidgiga1993
    Thanks!
    The input/output metering is also available in the free version.
    When using the free version, are the meter bars visible at all or are they just not being updated?
    Also the “allow bus processing access” setup button shouldn’t make any difference. It’s used for the XM32 version where the access can be restricted to a single bus. By enabling this option the user also gets access to the processing that bus.
    Yes, it’s also available on amazon now:
    Pro
    Free
    #52789
    robbocurry
    Hi David,
    I have my QuPac back in the van so I’ll check again tomorrow. As far as I recall the meters were visible (you saw the peak hold fading to zero) when the app connected but never moved again after that. No active meters on either version. I deleted the free app and was getting the same result with the pro app until I enabled the “allow bus access” button.
    I’ll check again tomorrow and let you know.
    Best Regards,
    Rob
    #52805
    Eddy_current
    Hi Rob/David, just checked with my QU-16 and all metering is working on my Amazon Fire with the free version, will update to the Pro version tomorrow. The app also works simultaneously with the Q-pad and Q-you apps. Many thanks Dave.
    #52809
    Profile photo of NZdave
    NZdave
    Hi
    Im new to using Android on windows/
    I have a few win 7 laptops.
    Which out of these do you recommend installing?
    http://techapple.net/2014/12/top-7-free-android-emulators-windows-788-110-pccomputer-run-android-appsgames-windows-78-110/
    Just to confirm; You plug the Qu-Android app directly into the Network port?
    You dont use a router?
    #52810
    davidgiga1993
    Hi,
    I’m using Genymotion but it’s designed for developers.
    For just running apps I would recommend Droid4X as it also has play store access.
    Note that the “Search” functionality of the app might not work when using an android emulator.
    You can either connect the mixer directly to the Qu or use a wifi AP.
    #52815
    NZdave
    @davidgiga1993
    I installed droid4X
    Downloaded the Mixing Station Pro QU
    Set the Mix station to same ip address but fails to connect?
    Tried both with DHCP off and on.
    The off live editor works ok in Drid4X
    anythoughts?
    Using HP i7 win 7 laptop
