QU-16 Editor?
Forums Forums Qu Forums Qu feature suggestions QU-16 Editor?
This topic contains 93 replies, has 35 voices, and was last updated by Profile photo of Valentyn L Valentyn L 1 month, 2 weeks ago.
Viewing 4 posts - 91 through 94 (of 94 total)
  • #65812
    Profile photo of garyh
    garyh
    For iOS and Android devices, transferring folders of audio files through the cloud would be easy enough, and desktops and laptops could use the usb drive directly.
    And yes, just using the multitrack playback for setting levels would be all that’s needed since you can’t adjust effects parameters using midi anyway. Now if A&H decided to release the protocol their iOS apps use, well that would be a whole new ball game. Until then, an app that could store levels, mix settings, channel names, etc. to files then send them to the board as needed, I think would be helpful.
    #65835
    Profile photo of [XAP]Bob
    [XAP]Bob
    I still don’t get why you’d want to ‘play back’ multitrack – you can set preamps based on something that doesn’t pass through them…
    Give me the ability to save a scene to the iPad, and maybe export/import to/from Dropbox/iCloud/gDrive/eMail/??? and that would be great…
    #65840
    garyh
    I could see a situation where you record a rehearsal, then offline, while playing the tracks, you could set approx FOH and mix/monitor levels and other settings for each song, band, scene of a play, etc. There may even be times where you need to change settings during a song. Basically it would become almost an automation tool where you can queue up your settings files and send them to the board at each change. You can do all this now using saved scenes, but the point of the offline editor is you wouldn’t need access to the board while creating the presets and someone could be making any needed changes to the files during the gig, on-the-fly, before they’re needed. You can’t do that while using the board.
    Again, all of this would be subject to the limitations of the QU’s MIDI over TCP/IP unless A&H opened up their iOS API.
    #66748
    Valentyn L
    +1 Editor the QU
