no output
Forums Forums Qu Forums Qu feature suggestions no output
This topic contains 19 replies, has 9 voices, and was last updated by Profile photo of BRS BRS 6 years, 4 months ago.
Viewing 15 posts - 1 through 15 (of 20 total)
  • #59990
    Profile photo of jakyrulez
    jakyrulez
    I’m not getting out put on my speakers
    But I can hear on my headphones
    I’m useing powered monitor mixer and peavey vsx 26 to get main out
    Need help have a show today
    #59992
    Profile photo of [XAP]Bob
    [XAP]Bob
    What output plugged in what amp?
    Desk setup?
    Alt out surface pot turned down?
    Need a lot more info..
    #59993
    jakyrulez
    I’m useing genelic powered monitor I’m not able to get sound from the speaker . I’m useing qu24 desk
    #59994
    Profile photo of SteffenR
    SteffenR
    maybe you should focus on knitting
    what is so difficult to provide more information?
    No info, no help…
    #59995
    jakyrulez
    What more information
    1) I have qu24 desk I have connected my powered monitor to L+R but there is no out put .
    2) I can get out put on headphone but not on speakers
    3) I even connected my speaker to altout but there is no 🔊
    #59996
    Profile photo of GCumbee
    GCumbee
    If you have sound on your headphones then in theory you should have sound on your main LR output and your Alt out. That is assuming you have properly wired cables. Your alt out has to convert from 1/4″ to what your speakers have. Are they balanced or unbalanced. That could be the problem. Check the preferences for Alt out to make sure it’s set for LR output.
    #59997
    jakyrulez
    It is LR AND IT IS BLANCED
    #59998
    Profile photo of croydon_clothears
    croydon_clothears
    It’s no good saying the same thing three times, we need MORE information – and RTFM.
    So you’ve proved you’re incompetent, let’s go back to class.
    1 – Are your speakers actually working? Check powering and that you’re in the proper input.
    2 – With LR mix selected (above main OP fader – blue light should be on) put Min fader to the 0dB mark and fade up a channel with some audio on it that’s routed to LR OUT.
    3 – The bright flashy LED thing that us professionals call “The Meter” should be lighting up green and yellow.
    4 – If it’s not, then you are listening to something on your headphones that isn’t on LR Out.
    5 – Have you got a PAFL button pressed somewhere? Check ALL THREE layers.
    6 – I’d have a good look at the VSX26 speaker processor if I were you – probably not configured properly.
    7 – Stop flapping about like a wet hen and follow the signal path PROPERLY through the system, tracking and verifying what works along the pathway.
    8 – Don’t blame the kit – most faults can be traced to the idiot who connected it up.
    #59999
    jakyrulez
    Speakers are working fine on another desk
    Blue light is on and fader is also on 0db
    There is reading on meter
    Ok will check it thank you
    #60000
    SteffenR
    make photos of your setup
    #60006
    jakyrulez
    Photos attached
    #60008
    Profile photo of Giga
    Giga
    No photo’s to be seen (over here anyway) 🙁
    Giga
    #60015
    jakyrulez
    1st pic
    #60016
    jakyrulez
    Desk
    #60017
    jakyrulez
    Images are not getting uploaded
